• All groups have different working dynamics. Is there anything you think is important to add to the algorithm? If so, complete the algorithm, even modifying it to mirror your working method.
• You can create other algorithms. For example, cake recipes are great examples of algorithms. These are comprised of ordered and relatively simple lists of instructions. Search for a recipe for something you like, and try to turn it into an algorithm. Can you do it?
Feedback
