• During this activity, you learned how to simulate two dice, roll them and have the cat tell you the result. Can you simulate three dice, roll them and get the cat to tell you the result? And, instead of adding up the results, can you multiply them? The process is very similar. You can add as many dice as you want, that is, as many sides as you want! Give it a try.
Feedback
