Learn More
The decoder you created is used to write and decode secret messages, using a previously created code of symbols drawn in the inner circle.
Create your own secret codes now. Cut out the 3 circles in white.
You can fill in one of them with the letters of the alphabet shuffled around, another with numbers, and another with symbols that you know! Or you can fill them in however you wish!
Downloadable document
Each of these circles corresponds to a different secret code.
In the Decoder you created earlier, you can replace the smaller circle with one of these circles you’ve just created to use your own code.
Try them out and have fun!
Feedback
